Is this wiring right? And what am I doing wrong
Are the phase wires touching?
Yes the phase wires are partially soldered
INSULATE THOSE DAMN PHASE WIRES!! please
What does that mean
This is my first build and I have no idea what I am doing
The 3 wires coming from the VESC to the motor, those are the phase wires. If they touch, while powered, your VESC is dead. Please put some heat shrink on em.
Okil have done this
What else should I do
You will need to configure the Vesc to your motor. You will need a USB cable and a computer loaded with the bldc tool. There is plenty posts about how to set it up, just use the search bar.
Did you mount the motor and vesc to the truck already ? Just to check the distances and so on… Just asking because you are not using bullet connectors for the phase wires. It’ll limit you when trying doing the layout on the deck.
I have and it fits perfectly
Thank you for all of the help
Ok thank you
This is why I love this forum. Everyone helps!
can’t really tell how good the solder joints are but looks like you haven’t tinned the motor wires which you should really but it might be ok
you need to program the vesc before using it
are you going to add an anti spark loop key to turn it off/on without sparking
is that the only battery you’re using? can’t see what size it is in picture
also as you’re not using connectors between your motor and vesc you might find it spins the wrong way and will be a pain to unsolder and switch the phase wires round, you could buy some bullet connectors instead so you can unplug them
Ok I will try resolder them and tin them better so that this might help I have programed the vesc and thank you for all the help everyone has given this forum is amazing
Yea thats a good point actually. If they have the wrong order your motor turns the wrong way… So just get bullet connectors or you’ll have to resolder them another time. Watch some youtube tutorials on soldering bullet connecters/soldering in general.
Hehe, fortune favors the bold… You should’ve added bullet connectors to the motor and the VESC. And if you’re doing that later on, look into doing the SK3-mod where you replace the motor wires with flexible silicon wire at the same time. The stiff original cables will sooner or later break due to bending and general wear and tear.
There is a thread for this if you search for “Sk3 silicone mod” or similar.
