I have no clue yet lol
are you sure those are PINK wheels and not RED? I thought mine was RED but on the other hand, it may be PINK?
270Kv might be a little high but it’ll probably work… 380kv as advertised in the title for ur motors would be wayyyy to much. I guess you’ll see how it turns out
What’s the normal kv?
There isn’t a normal, but a safe range for us is 150-250 or 270 MAX
I have pink on order. That’s just what I have for now. Going to take the gears off that set and put them on the pink ones. Same size same style.
What you see are red .
LOL @XvDarkVAngelvX thought I was going color blind. Please take some pictures of the “PINK” I actually dig it. Just like the “Baby Blue” color as well.
Now my set up will have the whole Enertion kit installed. So I will have the “Baby Blues” for you. Not sure what I’m going to call that rig just yet.
I believe Enertion’s wheels are translucent. Don’t dig that type of blue. I like the solid baby/sky blues. But I thought they were available in 90-93 or 97mm only. I’m ok with 83mm. For now at least.
Here are a choice of multi color 97mm. This where I ordered them from. http://m.ebay.com/itm/Blank-Pro-97mm-Multiple-Color-Longboard-Flywheels-ABEC-7-Bearing-Spacers-/151887095681?_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150519202348%26meid%3D6242624642bd4a1d99c2d448beeb98e1%26pid%3D100408%26rk%3D1%26rkt%3D25%26sd%3D151887083729&_trksid=p2056116.c100408.m2460
I’m currently constructing a work station🚉 to do my projects on. Here is the Double Kicktail Longboard Deck I’m going to use.
Nice…
You will need a bigger one lol
That’s just the frame. I’m working on the other side now
Yep, same here
270kv is fine…I think even @psychotiller has used 295kv
Def relegated to flats and gradual inclines…
Just use care when at stand still to kick off and pushing the motor to push u up a hill … Too many amps will def fry the motor
Ok , thanks. For a min there I thought we was going to have major problems. I feel so releaved .
One of the fav used…I guess not much anymore was the NTM 5060 270kv
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=30784
Problem is…seems to back ordered…since F O R E V E R
