First off huge thanks to everyone here, the information is never ending. I’ve been meaning to start a post for awhile but I now need advice so here we go.
Here is my full build list:
I have been hesitant to start as I might have been overly ambitious and decided for my first project I’d build my own battery as well. That meant buying or building a spot welder. I opted to build the spot welder. Of all the ways I saw to make one I landed on the built by Darkkevind1978 with a slight modification.
It worked incredibly well and I got the entire battery welded up very quickly. I could apply even pressure to each point as they were independent of each other. Here is the battery so far.
I was working on connecting my e-switch and I thought I was doing everything correctly. I have a DC-DC step down converter to reduce the voltage to 12V for my switch. I spent quite awhile looking for exactly how the switch connects to the BMS and came to the conclusion it was the 2 white wires on the BMS that complete the loop for the switch. Here is the diagram for the switch I was trying to use.
After connecting everything I pressed the button and the light came on as I expected it to but I also heard a fizzing sound followed by some smoke between the BMS boards… I don’t know what I did wrong, I’m hoping I didn’t ruin the board If anyone can point out my mistake I’d be incredibly grateful.
I’m waiting for my 10AWG wire to come in the mail so I can solder on the positive and negative leads for the battery. Hopefully I’ll have the switch and BMS sorted out by then. Here are a couple more pictures of the battery that show the welds a little better.
It just dawned on me that maybe the two white wires are not interchangeable and one needs to be positive and the other needs to be negative… that’s all I can think of…
The 2 white wire simply complete a circuit when bridged by the switch. I doubt that’s the issue as even a bad switch would just not trip the circuit and turn in the BMS.
Only if you connected the wires incorrectly ncouke that be an issue when including the power for the LED. Do you have a pic if how the bottom of the switch isnwired?
Well I’m pretty sure the BMS is toast… I put a load on the battery and the BMS dropped to 2.4V and didn’t change regardless of the switch being open or closed … anyone have a 10S Bestech Li-Ion BMS you want to sell? lol
Just ordered another BMS… are there any chances I could repair the damaged BMS? is there a fuse that can be replaced? I think I’ve read about a fuse being somewhere
haha it all makes sense now!! I didn’t realize the wires couldn’t accept any power… I had read somewhere that it could handle up to 12v switch but I don’t know… live and learn. Now I just want to figure out how to get the switch to light up only when the board is on.
install the buck convertor after the BMS, connect the POS & NEG to the switch and the on/off circuit to the BMS. Then when you hit the switch it will power the buck convertor and then the switch.
aww man… why didn’t I think of that… So the positive of the buck converter would still be connected to the positive of the battery its just the negative that would go to the “P-” right?
I would do it after the XT90 on the battery myself, that way its not completely tied in and is still removable.
What I mean is battery > xt90 female > xt90 male > buck > xt90 female > xt90 male > VESC(s). that way you can pull the buck convertor and reconnect without any reworking of the connectors. I prefer to make things modular so that repairs are faster and easier.
Dude you are the bomb!! (what did you use to make the diagram?)
Also, would xt60’s be sufficient? I have both 90’s and 60’s but the Focbox has a 60 on it
I used Microsoft Visio. XT60’s are likely OK, but I prefer XT90’s at the battery as they support higher amps. An XT90 on the battery and VESC side should be fine, then XT60’s after the buck convertor.
