Hi, will will anybody make me a antispark Koop key. I will buy it through paypal
really dude… you just need to solder 1 wire that’s less than an inch long
Really dude? you just need to use a dremel to cut your plug. switch and display holes…
woah there
too far
Just figured I’d level the playing field haha
you got paid extra to make those holes
i also ran out of dremel cutting disks
He said he’d buy a loop key…
and i’ll make it if he wants lol
just want him to do it himself since it’s cheaper and quicker
I don’t have a soldering iron
Well then shut up and make it Leo!!
Do you need just the key or key and harness that goes between vesc and battery
Why dont you have a soldering iron if you are making a DIY eskate???
Lol I’m beyond asking such questions at this point…
was just about to mention that
Hello guys. I tried to solder 12awg + xt90 with 30w and fat tip but it didn’t work. Even my friend, who is professional electrician, couldn’t do it.we used 60/40 solder, flux and tinned the tip and wire. But it took too long to heat the wire and connector. I researched a bit and came to conclusion that >80w iron is needed. So is this http://www.ebay.co.uk/itm/391864441800 sufficient? Thanx
Lol it’ll do it but it won’t be pretty or likely work long before burning out For added safety, fuse the key with a maxifuse or something similar https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/2708
Bought 100W Antex iron and worked perfectly.
you need a new soldering iron bro…get a weller for like 100 bucks, can’t go wrong…
