Just started doing my first build. I believe I got all the connectors right but when I plug in the Anti spark plug, sparks happens. Is that suppose too happen ?
Are you using the xt90 with a little green stripe?
I’m using xt90 but it doesn’t have green strip
Then you’re not using an Anti-spark plug…
This is an anti spark https://www.amazon.com/Youme-Anti-Spark-Connector-Quadcopter-Brushless/dp/B0732S5V85/ref=sr_1_10?ie=UTF8&qid=1516860284&sr=8-10&keywords=xt90
This xt90 doesn’t have the green strip but I do have a xt90 connector that do have one. Should I use that one instead
The one you have is a loop key. Although I am not sure if anti-spark works well with 12s
Yes what you’re using provides no antispark
Just check the tutorial on the forum http://www.electric-skateboard.builders/t/how-to-anti-spark-xt-90-loop-key/204
I don’t understand how you made an anti-spark loop key without an anti-spark XT90 connector.
So just change the xt90 loop only right ? To the female green strip ? I don’t have to rewire the series?
Lol it’s an anti-antispark
Yep just replace the loopkey
You see how you made a little xt90 key. Make another one thats the same but instead of the x90, use the xt90 with the green stripe.
Also if you could reduce your battery lead length, that would be better for the VESC
@scepterr reminds me of my first board with the plastic boxes and the terrible drive train sound lol
Don’t forget the anti-antispark too
“I have an antispark but it sparks all the time”
