Hi all im wanting to power my new build using dewalt batts… the 5ah are 5s2p and the flexvolt batts are 5s3p. Plan to run them as a 10s setup…
This was how i was originally going to power the board… Grouping the batts… 2 in series 2 in paralel… pretty easy to just use the shipping covers and modify with dremel/exo knife… but i think i might want something a bit less diy looking and more of a custom one off factory look…
Heres a couple designs which i think would both work well…or even better if there were put together?
First design… is more like an adapter to capture/harness the power from the batts… all good to go with 14g wire and a xt60 plug… https://www.thingiverse.com/thing:2435964
The 2nd is a flush fit for the dewalt batt… it has a section cutout to run the factory dewalt plug/pin out… i have a couple of these from some old tools/chargers… but you could easy adapt the two designs to make something which could be used buy others on this forum interested in running modular batt setups? https://www.thingiverse.com/thing:1809116
Thoughts?
