Hi all ,I’ve currently got a Trampa carver deck with mini infinity trucks and wanted to run either torque 110mm wheels or poss abec 107’s if I can’t run the 110’s . I’ve heard that in some cases you have to file down the truck hanger ends to allow the pulley to clear . As I’ve only just bought these I’d rather try and fit a pulley that has clearance. I’m not sure if the abec push in pulleys have a bigger inner circumference as the don’t require the bolts through the wheels into the pulley? If anyone can help or has the parts to check that would be great . Ideally I’m looking at a 40t pulley poss 42t Cheers
