I longboard/e-sk8 only from 7-8months, I used to snowboard before. I currently have this deck and I like a lot the drop, with 97mm wheels, risers and a slim enclosure that easily accomodates 1 “layer/row” of 18650 I can get enough ground cleareance.
I tried other decks but I feel that I’m most comfortable and safe on a drop down deck, I will plan to try a build with a kicktail and learn to use it well but for now having the stability of the drop at medium/high speed (~20-25mph wich are fast for me) is key.
The problem is that I’m almost 190cm tall (~74") and I would like to spread the legs and distribute the weight on all the board for maximum stability, and not go on the drop parts too much as I’m doing today because it’s a bit unconfortable maintaining such stance for a long time.
There’s a topic talking about drop down decks already with a good discussion and few builds that use such decks
tl;dr: Do you know any long Drop down decks? I can find max 43" I was searching 45"+.
Many thanks!
