I have 2 DIY 6374 motors and have shaft play and might need bearings replaced and I wanted to see if someone in NYC could rebuild these for me obviously at a cost. Please let me know.
Or if someone has links to purchase the bearings and such I can try it myself.
Look at the end of the shaft at the bottom of the can and make sure the play is not coming from the flat spot wear. Ive had that happen on different brands of motors. The fix is an aluminum weld and then grind it flat again.
Nope, just look at the bottom of the motor. There’s a flat spot on the shaft that rides on a flat spot on the can. Sometimes, with a lot of heavy riding the flat spot on the can will push out and allow the shaft to wobble and rotate freely.
The first time it happened to me I was really confused. Its the first thing I look for now when I have motor/shaft/wobble issues.
The first time I did this repair I took the motor apart to get the can separate from the electronics, you don’t really need too. Just be careful and be fast so you don’t heat it up too much. Any welding shop can do it, you need an aluminum weld though. Shouldn’t cost more than 10 bucks and takes 2 mins.
