Since it’s so cheap I figured I’d buy it to test some stuff out. Plan was to try and rewind them to lower the kV, hook them up to VESCs on 10S and slap some Abec11s on em.
If you’ve got these, what is the gear ratio and belt width? Also is the wheel pulley removable? In the description it says “wheel pulleys are enbeded with theels” not entirely sure what that means…
This picture explains everything, i didnt try to do this but apperently it is really easy.
“The three end wires can be soldered together for a Y configuration for the most torque and less rpm, or attach each end wire to one of the other two starting wires for a high speed low torque setup.”
I mean, if you want to rewind the motors you could do that but this should work so you have nothing to lose i guess. I need to rewind my burned out 5065 270kv and i cant get the stator off the motor screw plate, and it is proving to be a pain…
Sounds good, I’ll probably give that a shot at some point, thanks!
And if anyone was wondering, I got a response from the seller and the wheel pulleys can be removed, the belts and pulleys are 15mm wide and gear ratio is 12:36.
I haven’t seen it done like that before LMT put 6 electrical binding posts on some of their motors so you can either use their pre made saddles or solder them up with wire to get either config… pretty cool
I wish my motors had solid posts to attach flexible wire to rather than inflexible wire
@NickTheDude Great, china is taking over. Bad news for eu suppliers, i hope this forum wont be for fixing china eboards that rookies buy. Make sure to update us on the kit.
@Cobber Soo cool, so it should work as the three delta wires are split and bridged into wye on the same side, leaving three thinner wires as A, B, C.
Same, I should have a set coming soon. I got 2 TB VESCs. Their not the best in the world but I’d imagine you’d run into a bottleneck at the motor before the VESC so they shouldn’t be working too hard.
Hey man this is a bit off topic but if I want to change my motors stator from delta to wye how would I do this? I though I new but then your LMT post and the picture the other person posted look different and I got confused. Could you help me out with a quick pick or something, thank you
