I need to buy some more, but I forgot if it was M4 or M3. im using sk3 63 motors
Probably M4
it’s m4.
10c
Thanks and love
Make sure not to get ones that are too long, 8mm should be fine
10mm is standard
Now that I know, thanks for reminding tho.
I tried both 10 and 8 both works fine. 10 is kinda close to the core tho
I use only m4x8mm and it’s close, depends on the motor mount thickness
your mounts are too thin
The screw holes are recessed the arm itself is thicker
