Hi all… (@flatsp0t—I’m hitting you up).I’ve been putting my stuff together and after a few problems were worked out (with mechanics, not electronics) I’m ready to get some VESC stuff going. I’m 185lbs & I’ve got a single Torque Boards 6374 (Hall sensor, but not connected) hooked to a DIY Skateboards VESC & Space Cell 10s3p with integrated on/off, etc… I did the motor detection & followed the DIY tutorial. So far, so good. I’ve written everything you see in the shots. My controller (2.4 nano from DIY) should be here tomorrow, so everything I’ve done so far is without a transmitter/receiver. Really just want to check that nothing is crazy out of line. Also, if I ultimately run in FOC mode, which I think I eventually want to do, will I fry the VESC? Getting a lot of mixed info as I read.
Random stuff that might help about my setup:
Motor: TorqueBoards 6374 190kv Max Power: 3150 Watts Max Amps: 80 Amps
VESC: DIY Skateboards BLDC with micro USB connection v4.12 Hardware v2.18 Firmware for FOC
Battery: 10s3p with 40amp fuse
Thanks in advance, all!
