I’ve recently build a Trampa mountainboard with dual 6374 motors. I’m currently running sensorless FOC and after being used to just using sensorless BLDC on my Vanguard build, the startup smoothness is already a fair bit better but I don’t think it’s quite good enough for when I’ve got my feet strapped in and am going on off road tracks so I want to install sensors of some kind on my motors.
This looks like it’d be the simplest approach for adding sensors to my build.
Btw the reason I didn’t just buy sensored motors in the first place is because the built in sensor PCBs that come with motors generally aren’t waterproof and so I wanted to opt for a solution that I could install myself after applying several layers of conformal coating to the sensor PCBs.
I have been using those same sensors on my 5065 for some time now. They work great with my vescs. They also share the 3d print design for a mount wich is nice. They’d didn’t respond to any of my emails with questions however:sob:
I did also design a printed cover as the sensors ends up too exposed
Look up Nowind and his vesc 6.4 v leopard topic, he adds a cage around his motors about 1/3 through and a AS… encoder chip. It is next level compared to epoxy magnets
Not gonna lie, I’ve been really tempted to ask him about ordering a pair. I really should stop spending so much money on this hobby at some point though… Need to look more into the different sensor that he uses in them
I just bought one from him, it is being packed tonight.
Hit JensoBro up if you want one I know he made a few, I know only one or two others who have ordered so you might get lucky if you get in fast!
