Im about to start with my build and im trying to choose a BMS. I know theres another popular Bestech model but HCX-D336 is only 8mm tall which is perfect because i want to make my battery enclosure as small as possible. Do you guys think thats an ok choice? Btw im thinking to use it with 10s4p configuration with prob 190kv 6355 motor(s)
im totally new in this hobby, im not sure about what that battmax means i guess its in VESC settings. i read everyday in this forum about all sorts of things, slowly getting somehere im thinking to use samsung 30Qs they are rated at 15A so that would make 60A discharge i will get 10A headroom if that makes any sense.
the 30q are safely rated at 20a, but it’d be good treat them as if they’re 15a. good to leave headroom like you said.
yea, batt max is a vesc setting, it limits how much current the controller will pull from your battery pack. so…set it 60a total across the two motors (30a each) and you should be good.
also, keep in mind there’s a 2qt minimum order when ordering from bestech.
ok got it i just got a response from bestech saying this model is discontinued. i thought it was perfect for me. the popular option at 80A is HCX-D223v1 but its really tall 25mm compared to what i chose which was 8mm. i think the next best thing is this one (13mm tall) with built in e-switch but rated at 60A http://bestechpower.com/37v10spcmbmspcbforli-ionli-polymerbatterypack/PCB-D345.html
theres this one rated at 60A aswell looks slim enough in the pictures http://www.batterysupports.com/36v-37v-42v-10s-60a-10x-36v-lithium-ion-lipolymer-battery-bms-p-267.html but people say if you go out with full charge and try to brake, it will cut off the power to prevent overcharging the batteries. this particular scenario is not happening with bestech products. other than that its not bad for its price i think.
