Ok,
This is just an idea I do not know if this is possible or if it would work very well, I just wanted to share my idea and see if we could brainstorm.
Instead of leaning to turn you will have a joystick that can go forward, backwards, left and right. so if you wanted to turn left you push left on the joystick and that will send a signal to the Arduino that will slow down the left motor so the right motor is dominant and depending on how far you push the joystick is how sharp it turns.
you will obviously need 2 motors and for them to be in the front of the skateboard. and solid trucks.
I don’t know if this idea has already been made or shared (apoligies if it has) but I think it is quite interesting and if I was to make it I would need to do a lot more research and thinking on how it would work.
Its physics, when you lean, you turn the board and the board gets you back to standing position, like try to lean while standing up not on a longboard, youd fall. And if the board turns and you dont lean, you would get thrown off your board the other way
Skateboards dont turn as much as longboards and go as fast as them so you dont lean that much when turning, get your first set of longboard trucks and try to carve and youll know what im talking about
Ohhh yeah. maybe theres some way around it like strapping in your feet. I really like the idea of turning with a remote. maybe you could leave the leaning in trucks
Then youll need a extremely heavy longboard and might aswell weld your feet on the deck lol, have you ever ridden a car and when the car turns you feel like youre being pushed the other way, thats the same on a longboard
That wouldnt make a difference as long as you turn, traditional skateboard trucks barely turn, and the way most people turn on a skateboard is that they use the kicktail and its only used at low speeds,
Yeah if this idea did work, then a single drive board simply wouldn’t work as you’d constantly be turning. Also when you lean on either a skateboard or Longboard the trucks physically turn the wheels to the left or the right and that’s how you turn.
