This section of the code was taken from drv8301.c. I have 0 understanding of what has been typed in the source code.
I am having trouble understanding what the 2 and 0x0430 stands for. My current understanding is I believe the 2 refers to the address 0x02 in the datasheet and the hexadecimal value of 430 refers to the binary value for 0x02.
// Disable OC
drv8301_write_reg(2, 0x0430);
I need an explanation on the code below.
* @param val
* The value to use. Range [0 31]. A lower value corresponds to a lower current limit. See
* the drv8301 datasheet for how to convert these values to currents.
void drv8301_set_oc_adj(int val) {
int reg = drv8301_read_reg(2);
reg &= 0x003F;
reg |= (val & 0x1F) << 6;
drv8301_write_reg(2, reg);
