Hi, how do you attach the battery to the Trampa board? I’m looking at the standard is one plastic pad in the middle and a battery box screwed to it. Doesn’t it sway? I’m thinking of two washers, on which I’ll put a screw with springs between the washer and the battery box. This should eliminate plate bending pressures. Does anyone have that?
If you have only one plastic pad, what size (height, width) will you recommend? I will add a photo for inspiration. up and down comes an aluminum plate 5mm thick, I cut a parade into it: D
Hi, I’ll probably just be a reader, thanks to my language barrier, but I’m building a board and this might be useful to someone. These are stl files and dimensioned images that I designed. so much fun in the beauty ride.)
https://drive.google.com/drive/folders/1kdYmuT0CZ66XUoS2ko8d_ZKUGG5uq-ym?usp=sharing
