I recently purchased a FOC box Unity to upgrade my basic ESC, which I had run sensorless, I soldered on my own connectors to the Vesc, 4 mm bullets, and an xt60. The motors run fine without the sensor, but when I plug in the sensors one motor continues to work and the other locks up completely and hums a little. video of me showing this
Please share a photograph of the sensor connections on the motor.
Also, what software are you using to setup the motors?
I am using the FOC box UI app for Android connected via Bluetooth to program the motors.20201121_215617|375x500
20201121_215653|375x500if those bullets touch the FOCs dead
Yes, I am aware I plan to wrap them in electrical tape when I am done, Thank you though!
I strongly advise using heatshrink tubing. it will hold up better.
Also,
You need to make sure the pins are matched with the correct wires on motors.
There is a good chance your TEMP wire is going to H3
Thank you for all the help. I think the app wasn’t working because I couldn’t apply the configuration. I just ended up using the Vesc tool which means I lost push to start and timer turn off, but it worked in the end so it doesn’t trouble me too much.
I think the timer turn off works with VESC Tool.
