Just bought all the parts for my longboard (no electronics yet) and I’m getting a good bit of wheel bite. When I turn normally it doesn’t happen but just a tad bit more and I’d eat it.
Any suggestions? It’s a pintail board, Caliber II trucks, 83mm flywheels, and 1/2" risers.
You use angled riser pads instead of flat ones. you can also tighten your trucks or add a couple washers under your boardside bushing (those red squishy things)
Different angles will change where your wheel comes closest to your board. Check what point that is and make sure that’s where your wheel well is centered. Expand it a bit so the deepest part is in the right place. You can also measure where the back of your wheel will hit. That’s as far in as you need to make your wheel well.
Thanks – I just put some even bigger risers on and wheel bite only occurs when I’m turning ridiculously hard. I also tightened up the trucks and that helped. I may end up making new wheel wells also.
These should give you more room than a regular 1/2 inch riser because these change the angle more than the height … note these also changes the Truck geometry and make it carve more …
You can try normal riser in front and angle in the rear
Depends on what you’re going for but the typical modification for high speeds / downhill is to de-wedge the back for increased stability (less rear turning and less chance of speed wobble). De-wedge means the fatter end of the riser is facing forward. Some longboarders are de-wedging to the point where the rear truck is set to zero degrees (the rear truck leans plenty but doesn’t turn, so turning dynamics are more like a car). I’m one of those people.
If you find that your resultant turn radius is too large, you can wedge the front for tighter turning.
