Trying to set up FOC hall sensors, with a SK8 6364 and FS4.12, the detections all work fine until I get to the hall sensor detection, the motor spins but just an error of a bad result, any ideas?
Tried it with my other SK8 6364, same result. What order should the wires be that go into the vesc?
I might be wrong but don’t you need an adapter for the sk8
Honestly that would be news to me, I’ll have a look around and see what info I find
Tried messing around with swapping the pins and no luck
How many wires are in the connector
6 wires, trying to take one apart now to see if the sensor is still intact
Some times it can be the board contact HK about it
Yeah I think I will
