THE BADFISH BUILD
This build has been in the works for quite some time. I had originally planned to do this months ago, but it is finally coming together.
Thank You guys, YES finally this thing will be rolling in a week or so. We plan to put a few more together using mbs decks HELA BATTERIES for them so we will a good selection of (kit) boards for everyone to ride, Comp 90, core 94, colt 90 all with matrix II trucks and rockstar wheels, eboosted HS11 enclosure, all necessary things to go.
It’s even better for a visual inspection, You see everything.
This with the D127 we now can set the bms in 2 positions with out changing anything
For example,
note the bms is just tape down and can be pulled forward of the pack
I can trace every balance wire from battery to jst
I like the clear heat shrink
Especially if you use something like cell level fusing it should be the only way to use clear one.
If one fuse triggered you can see that directly without a need to open up everything.
Benjamins Middle name is CAINE…
coincidence I think not
We are also going to build a 10s6p out of the Samsung 50E as a continuation of this thread. we have 3 batteries to build for LA CRIOX decks 1 12s6p pictured above and 2 10s6p Samsung 50E we will chronicle one
