Update on the diagram
That looks good, I would only suggest to move the display after the BMS, so it can turn off too, unless it has its own switch
Thats a good idea, thank you!
AliExpress. Although I can’t seem to find the link at the moment
But on your updated diagram, there is still nickel strips AND AWG wire on the spots numbered 3, 5, 7 and 9. Is that correct ? Because it seems different from what @b264 showed us on his diagram.
Oh damn, did the seller remove the listing or something?
Not sure
what nickel strips are you using between the cells (middle of the pack) @darkkevind ? I’ve seen some builds with ladder style nickel strips which are not made for high current draw!?
Or let’s phrase it differently, what would you use for higher current draws 60-80 Amps?
He is using ladder style, but he is probably using the good kind
Yes @moon definitely the good kind.
Each ladder run needs only carry the current of one cell to the other, so they are well within their capabilities @anon42702729 …
