And I’ve installed them on my 6S4P 18650 battery pack. I didn’t checked the 18650 cells before building the pack because even if they were from aliexpress, they were in theory brand new LG HE4. After the first ride, I’ve noticed the performance was much worst than expected (like having 4/5S, 3/4Ah, 15/20C, pretty crap, and the output power was coming straight out of the batterys). When I’ve tested the batterys after 3 or 4 cycles, most of them were unbalanced.
Now I’m planning to go back for a Hobbyking Li-Po build and I’m planning to re-use those BMS, so my question is:
Has anyone got a bad experience with the those BMS? Or do you think I was just unlucky and I’ve been scammed with the 18650 cells? (24 of them costed me 85€ free shipping)
Thanks for the info. In my case, a 6s4p 18650 pack didn’t work really well. I have 2 theorys, the first one is that the wires were not enough AWG and the second one is what I told you before about the cells quality. But I think its more likely the second one cause I used to run my esk8 with same wires but on hobbyking lipos and it used to work perfectly until after shorting those a few times accidently, some of the cells got damaged
