Just ask Alan ( @Eboosted ) to supply the battery complete with bms charge port and indicator etc. wired for charge only. Make life so much easier for you.
The only problem is that I already have an Arduino running on Bluetooth. I am also planning to buy the FOCBOX Unity which has Bluetooth too, don’t want more than 2 radios…
I want to be able to check the voltage of my cells, and also get a signal when charging is complete. I heard that Enertion was planning on an app for the Unity, maybe that could give me this information, if not I want it sent to my arduino which I use for my remote.
Yes. I supply everything you will need, charging port, wires for charging ports, even the heat shirk, antispark switch, bms, on/off switch, XT60s and if course battery and enclosure with bolt kit.
Charger too, I don’t have it on my website though, I could offer a 2A, 3A or 4A, I suggest the 2A as they batteries will have a longer lifespan and it’s better if they ever go out of balance
