Over the next week I’m going to be disassembling my 10S4P 18650 battery and rebuilding it similar to the way @chaka builds his with 3D printer cell holders and cell level fuses. As well as this, the battery is going to be built into 6 smaller packs (4x 2S4P, 2x 1S4P) that are connected together in series so that each pack is under 99Wh. This way I can easily pull the battery apart when I want to be able to take my board on a plane.
For connecting the power cables between each pack I’ve bought spade connectors (which will be insulated with heatshrink) as they’re a bit thinner than bullet connectors.
I’m then looking at using servo cable connectors for the balance cables.
What do you guys think, should these do the trick?
