Rookie question all things considering, but I have two batteries wired up in parallel. Both are 10S2P. Does that mean I have 10S4P when calibrating my voltage meter?
Also, I got an anti-spark switch that handles 100A. Is that enough? Not sure how to calculate the amps.
It’s just a Meepo board with the Samsung battery that it comes with and then I added the Sanyo battery. (You can see them on their website). And I weight 205lbs.
I want to add LED lights and a better battery meter and honestly I can’t digure it out with the current setup. There is no source on the ESC that has 40v when the thing is on and 0 volts when it’s off. So I figure I get a switch and control it that way.
