i took of the strip! And i cant remove the little spot that’s ledt behind!, can i re-spot it again (cover with strip)
Thanks
Thanks
I think people who remove them sand the spots off. Metal isn’t that thick so don’t go crazy
You may blow a hole in the nickel strip you are trying to spot weld if when ur welding the tips touch that spot
Thanks for the info bros,
@E1Allen just want to make sure, dont want to burn my board, i think im gonna sand it
@willpark16 thanks!
I guess to your advice I have to. Sand the 210 cells I salvaged last month it’s gonna be a pain in the ass
And use some isopropyl alcohol or acetone to clean afterwards before welding
