Hi! I’m about to make order on hobby king, so i need a few things to know before order. So i’ll be using 2x 4s 8000mah batteries in series: http://www.hobbyking.com/hobbyking/store/_38301__ZIPPY_Flightmax_8000mAh_4S1P_30C_EU_Warehouse.html?strSearch=4s%208000mah
Do i need order this to get my batteries in series to get 8s from 2x 4s+ using antispark connector: http://www.hobbyking.com/hobbyking/store/_10264__XT60_Harness_for_2_Packs_in_Series_1pc.html
Do i get it right or i need other things to connect my batteries in series+ anti spark?
So how can i connect it to batteries, do i need some special harness to connect together batteries indicator cables, or i just plug both indicator cables from both batteries straight into those meter devices?
What kind of on/off switch should i use? I want to put fuse on batteries, how should i do it, what kind of fuse do i need? Fuse on each 4s battery or one fuse on both batteries?
Both. More charging inconvenience. I had one set go bad when my series charger started smoking and another when I used the parallel charger (didn’t balance the cells well at all). I’m on my third set, each set costs just over 50$ with tax and shipping. By now I could’ve just bought a li-on and been better off (which is why I’m looking to get a new battery before these ones fail me)
Take a look at this thread, there are some good diagrams.
For charging there are three main options: series, parallel or each pack separately.
If you choose series charging then you need 8s capable charger, e.g. turnigy 1000w which is quite expensive.
For parallel charging you would have to switch (disconnect) between series each time you charge and also you maybe want parallel charging board. Remember to choose appropriate / matching connectors.
