Hi, as I am about to embark on building my longboard I have a question.
Context:
I am going to be suing two 5s batteries hooked up to a 10S BMS in series.
I’m wondering how I build in a battery capacity display so I can see what % my batteries are on when riding it. Anyone want to tell me how the battery capacity LCD works and where I would put it in my board?
They work by soldering the positive and negative leads coming out of the meter in parallel (pos to pos, neg to neg) to a positive and negative lead in your setup. I recommend putting the voltage meter after your switch so that the meter only comes on when your system comes on. I use one similar to this but I would recommend a less bulky one like @Jinra showed. You can see my diagram for the voltage meter here.
What I did in case it stopped working or I just wanted to unhook it, was solder the indicator to a xt90 connector. Then I connected it with a parallel connector between the batteries and esc. Works really welL and can just plug/unplug it.
