Battery Monitors how low to go?
So random question regarding those LCD battery Monitors people have been putting in their builds. I have see that you never want your lipos to go below a certain voltage level (3V/cell I think it was) My question is these battery monitors, does that save level correspond to 0% on the screen? Or do I have to pay attention and stop riding at say 20%? Also would the board keep function beyond that minimum voltage cutoff? As in could I accidentally ride my board too long until the batteries become unstable and dangerous? If it makes any difference I have a VESC and a 60A BMS in my setup.
This is the monitor I was reffering to: http://www.ebay.com/itm/172143986261?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This is an approximation of how voltage level corresponds to meter %. You’ll have to check the datasheet of your batteries, but lipos lower voltage limit tends to be higher than li-ion.
If you are looking at the DROK DC8-63V Volt Meter, which is what most people use, you can switch it from percentage to voltage on the display.
I usually charge my cells to 4.2v & run them to 3.6v (@ 6s total voltage = 25.3v top to 21.6v bttom).
There are 2 styles (I didn’t say model, because the model numbers are the same). On both styles, you have to solder a button on the front. On the old style, you have solder points on the back that you bridge for different functions. On the new style, its all done with the 2 back buttons and the front button.
Here’s a youtube video of the old style.
