Hi guys, I recently upgraded to a Flipsky dual + 4.20 VESC with the built in anti-spark switch and I realized I have nowhere to connect my battery monitor anymore. It is just two wires that are meant to be connected to the positive and negative sides of the battery after the anti-spark switch so that it can measure battery charge percentage while the board is turned on.
Does anyone know if this is still possible? Are there two pins that’ll give me the battery voltage after the integrated switch or is there some other solution? How do other people get their battery charge when using this VESC? If it helps, I have the 10s2p Meepo ER battery and this battery indicator: https://www.amazon.com/gp/product/B01LQ7MT4K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1.
That’s unfortunate. I’ll check out the battery meter with a switch, thanks!
Is there an app that can read out the battery voltage as a percentage? I know the VESC app can give you voltage but it’d be nice not having to convert that every time
The discharge voltage of lithium-ion is far from linear, and thus not suited well for capacity measurement.
That’s why VESC for example does actually measure the used energy to determine the remaining one.
