Hi All,
I recently fried my battery at the last stage of a new build and now I am looking for a replacement battery pack.
Does anyone know where the best place to buy a battery pack is in the UK?
The battery that I just killed was a Alien Power Pack 8S4P that i had used in my last build.
The new build that I was working on was going to be a dual 5065 200kv setup with evolve AT wheels
I never got to test the battery with the dual 5065 motors. However I took it for a short spin when I only had one of the 5065 motors installed, and experienced what I assume to be voltage sag on a very slight incline. As such I was a little concerned that the performance might not increase enough after installing the second motor.
So as I have the opportunity to upgrade the battery pack, is 8S4P still a good configuration for a dual 5065 200kv setup with evolve AT wheels, or should I be looking to upgrade to 10S?P?
Ideally I’d like to buy the same 8S4P battery pack again as I have already cut out the enclosure to match the battery display, power button & charge port. However I worry that it might not be strong enough. Has anyone got an option on whether 8S4P is a big enough battery for this setup?
Anyway, thanks for reading my thread and here is some skateporn of the two builds I was working on before i killed my battery:
Note: my plan was to swaps the battery & enclosure between the two decks depending on what ride style I wanted.
