I need to tap into the bountiful wealth of knowledge within this wonderful electric skateboard builder community for this one. I can’t get my electric skateboard battery to turn on.
Some background: I’d been happily riding my DIY esk8 (using an Enertion Space Cell Pro4, a 170kv motor, FOCBOX and GT2B controller) for a while last year until disaster struck - I went over a sidewalk while skating and the impact of the landing literally tore my truck in half. The side of the truck with my brushless out runner and wheel simply separated and got torn from the board, forcefully unplugging the phase wires from the motor and switching the board off. As I was on the cusp of a semester abroad, I thought I might as well approach the problem later. Well, now it’s later and I’ve rebuilt everything to get my skateboard back to its former glory… except that now the battery won’t turn on.
First, I thought the battery was just totally out of juice after my time spent abroad. But I just ordered a new battery charger from @JLabs and, when plugged in, my battery still won’t take a charge.
Then I thought maybe the switch was faulty. I’d already replaced the switch on the original battery, but I’ve ruled out the switch being the issue as the battery won’t turn on even if I make contact with the two white wires going to the switch itself.
Now I’m thinking that it’s a greater problem, like maybe the BMS was harmed during the crash, or maybe the motor being yanked out from the battery also tore out some type of solder?
If someone out there could kindly take a look at my video and tell me what you think the problem might be, that would be hugely appreciated. Thanks in advance!!
The thing you don’t know what it is, is your fuse.
If you have a multimeter, take out that purple thing and measure the resistance from one leg to the other. If it’s 0ohm it’s fine.
Put it back to the holder than measure the voltage on the yellow plug. It’s the xt90 plug which gives the power to your vescs.
If it is a 10s battery pack than voltage shouldn’t be under 25v, for 12s not under 30v.
If it’s over that than it looks like your bms is broken and you need to replace it.
If it’s under than your cells probably fucked.
I didnt watch the video but make sure you open up your pack and see if all the welds still hold
if they hold and your battery works normally without the bms the bms is dead
if they do not get ta new pack or reassemble the whole pack
How old is the pack?
Yes please. It’s the only way to make sure what’s going on with your pack.
There are cheap ones in every hobby or electric shop. Does not need to be the high end fluke…
@Jake2k17, I did turn the board off when the truck snapped off. However, my brother just told me that while I was away, he noticed that the board was actually on for a couple days, and that he didn’t think twice about it and then after a couple days it was off… weird that he didn’t think to try to turn it off.
I’ll get a multimeter by tomorrow and let you all know what’s up.
you almost certainly had the issue I did, you left it on and now the pack is flat. You can sometimes revive flat li ion batteries with trickle charge until its at a safe voltage again… make sure you monitor everything please.
@Andy87, turns out my housemate has a multimeter that I borrowed. The fuse read 0.6
And when I checked the voltage on the battery at the xt90 plug, I couldn’t get any reading at all…
Is it worth trying to rebuild the battery? How can cells become “fucked”? I assume that means they’re not fixable, at which point it sounds like rebuilding the battery is kind of pointless…?
You should check the voltage not on the xt90 but directly to the main positive and the main negative directly on the pack! This to exclude bms fault, actually the bms should have protected cells from discharging.
Check the voltage directly to the +and - and then if you have 0 it means for sure broken series connections
I saw this cool thing these guys did with the boosted board, it was way over discharged, and one drove a car really slow and the other held onto a rope that was attached to the car and then he towed him until the rechargeable brakes powered the board on enough to charge
Interesting idea. I assume the board could turn on though before being pulled by the car? And wouldn’t the battery cells be able to charge up normally with the wall charger that I have? Why the need to “trickle charge”?
Sorry my bad…yes can be the bms don’t give you to read any voltage.
So you need to measure on the last cells of your pack. There is in the picture on the left side the big red wire and on the right the big black wire connected to the pack. Measure there the voltage.
