Iv been playing around with how I’m going to fit every ting in the enclosure and now decided I can get a 10s 3p in there as a single stack instead of the 3s 9p I thought I was going to have to use. I’m a bit stumped in the best way to orientate the p groups and path of the current through the battery pack. has any one got a opinion as to a preferred routeing through the battery and why?
intended to use nickel strips on the p groups and 10mm by 1mm flat tined copper braid for the Series links and the rectangles is a DieBie BMS if it makes any difference all to fit in @bigben tayto encloser.
probably going to bail on the Samsung 30Q iv got and get some Sony CVT5A instead as I want settings to be dule +35A -25 motor and +60 -18 battery as I think I be running the Q30 to close to there limit and I had region limitations in the past at lower settings range isn’t really a factor as its more of a commute build this time and the packs bigger then I need KWH wise as I normally on do 10 miles a day.
