I’m up for bora bora. All inclusive? What trucks do you have?
What’ your goal here? To fit trampa hubs on your axle?
If is possible. Don’t want to buy a Torqueboard if I don’t have to… but Frank already said minimum 36 mm of axle are required (not counting 10 mil from the tread). I think I just got 32 mm total from my Evolve axles including the tread. So I’m short by 14 mil at least. No luck.
Cut off some of the hanger just enough to reach the desired amount if you don’t want to spend money.
Same trucks here, any update yet?
Just clean them and treat them right…they’re rated for 24krpm
Does anyone know if it is possible to fit Superstars onto SurfRodz RKPs?
Yep, you just need to figure out the axle size and match that to the bearings. Most sizes can be had in Amazon or eBay.
Hi Guys!
I’m vaiting for my 6,5in superstars to arive. I have 638 2rs bearings to fit them on to the TB 218mm trucks, but the question i have is what kind of bearing spacers shoudl i use? Trampa uses 12x16x18.2 for 12mm axles right? So regular skateboard spacers will be to short… and there is no 18.2 8mm spacers that i can find. Any ideas?
Here is your solution guys.
