Hi, I have a benchwheel dual motor belt drive skateboard that the battery has failed on. it had 24 cells 6s 4p I think, with the + - power leads and 5 + wires from each set of 4 cells going to the controller along with a temp sensor.
I want to get this board going again but want to know what battery it could take, does it need to be 6s? And would I need to add the 5 voltage check wires to whatever battery i use or if its the correct voltage would the board work without these.
The original battery wouldn’t charge and when inspected I found that a lot of the spot welded tags had come off cells all over the battery, the cells are mostly 0v and can’t be revived.
Thanks.
Thanks.
