Best configuration for 6s battery out of lipos
What is the best possible configuration for the best speed and range with a 6s battery?
2x 3s 8,000 mAh
Would it be bad to do 3x 2s 5000mah just for the sake of being on a budget.
no, that’s pretty close to what a boosted board uses. You’re good.
Ok Thank you
For speed, try: 15T/36T-- 20mph 15T/36T–22mph with 83mm wheels
6s / 5000mah your only gonna see 5-6 miles range Better go with the 8000mah if your gonna do 6s Or get two 6s / 5000 and put them in parallel for 6s/10000 for 10-12 mile range
