I’m getting 27mph with my current board but I want a higher top speed so I’m building a new board. Here are my options:
Motor Pulley Teeth: 13t or 16t Wheel Pulley Teeth: 32t (it’s Evolve so it might actually be 33t?) or 40t
What would the best combination be?
Depends on the size of your wheel
It’s 107mm!
I would go with a mínimum of 14t on the motor, less than that you bend the belt too much and reduce the life of it by a lot
Calc.eks8.it
Current setup is 36T/16T with 90mm wheels with dual 6374 motors on BLDC, I enjoy the speed uphill. Esk8 calculates ~32mph weighted. If you use the same setup with 107mm wheels, Esk8 calculates ~38mph which to me is plenty of speed.
Alright I guess I’ll just invest in 36t, I just already had 32t and 40t so I was hesitant to grab 36t haha
Or if you have 40T/18T setup, it’s similar gearing ratio.
