I am about to set up my dual focbox vescs (via cambus). I have a 12s4p 60amp SuPower (BMS), and dual 6374 190kv motors.
I want to make sure I set these correctly:
Motor Max,
Motor min (regen),
Batt max,
Batt min (regen),
Absolute max
Also if you have suggestions for:
Minimum input voltage
Maximum input voltage
Battery cutoff start
Battery cutoff end
I want to be able to have good braking for going down hills. I will also use BLDC but might try FOC mode in the future.
Thanks for any help, I have searched up and down the forums and people seem to be varying their opinions for these settings. (I have my own opinions but I don’t want to influence the decisions.)
Is this your first board? Do you have a Bluetooth module to easily change theses settings?
Here’s what I’d start out with:
Motor max: 60
Motor min: -60
Battery max: 30
Battery min: -8
Absolute max: leave it alone, I think its 130
Minimum input voltage leave it at 8
Maximum input voltage leave it at 57
Battery cutoff start: 36 (3 volts per cell)
Battery cutoff end: 33.6 (2.8 volts per cell)
I gave those settings per VESC. Only battery max and min need to be split.
Absolute max I believe is just a cutoff point, if you exceed it you’ll get some error like: abs_over_current. All I know is that it should be left alone at 130
This is my first board, but I am a pool skater and I am used to the speed and have good board control. I wonder if I should put the battery cut off a bit higher, around 41V or 40V. I think that might be safer? I had it at 20% when I built the battery and it was around 41V (3.41V per battery).
Yes, made a few adjustments, changed the 40a to 50a. If you want to run hard you can change that to 60a and it will be insane. I’ll get some screen shots later
i would like to have advices about my Vesc setting with VTC6 sony li-ion battery
it’s a 12s4p 12AH bms charge only
i have an orrsom board from Trampa with two 6364 154Kv motors
i would to know the setting for
MOTOR CURRENT MAX : ?
MOTOR CURRENT MAX BRAKE : ?
BATTERY CURRENT MAX : ?
BATTERY CURRENT MAX REGEN : ?
and also about :
Battery cutoff end
Thanks a lot for for advices i realy don’t want to burn it all
