Bldc OS X vesc has newer firmware (2.53) than bldc version supports
Hi I’m getting this message with my new vesc x and need help doing this properly without blowing a vesc-x. TIA!
Did you change the firmware? Should be 2.18 by default
I just bought the raptor off someone. (I sold my last setup too early, and my Carvon’s and raptor 2 are taking too long, so needed a board pronto) lol But this is how it came so trying to get it sorted
Try this:
http://www.enertionboards.com/electric-skateboard-parts/new-vesc-x-speed-controller/vesc-x-bldc-tool-mac/
Ah ok, it has @Ackmaniac’s firmware (2.53)
Did you install the BLDC_Tool from here http://www.electric-skateboard.builders/t/extended-bldc-tool-with-watt-control-mode-ppm-cruise-control-individual-throttle-curve-and-android-app/12286. Because that’s what firmware your vesc’s are using. You can use the regular BLDC_tool but you would also need the corresponding firmware for it.
Is this different than the standard BLDC tool ?
No it’s 2.18 also
got it. @SeanHacker sent me the link… appreciate all the quick replies… this forum is amazeballs. a couple other questions though.
  1. how are the R-Spec Duals in FOC mode? if it works well, does somebody have saved parameters/values i can piggyback off of?
  2. i just bought the 12mm pulley kit. First of all, does it fit correctly or do i need to dremel the truck a tad, and is there really more torque? Basically asking, are these components worth upgrading to on a dual setup? https://www.dropbox.com/sh/t7dl90owz5ccbyl/AADNOs3g9TfYw-VAyYey3hZNa/BLDC-TOOl%20and%20Firmware?dl=0&preview=BLDC-Tool+ACKMANIAC_Mod_MAC_2.53.pkg.zip2
IMO, let the dual motors roar in BLDC
