I went from 6S to 9S on a 245kv, Enertion Vesc setup and have a question -
I weigh 167lbs - and on 6S, I was getting a 20mph top speed, on 9s, it seems about the same, maybe 22mph. I think maybe I missed a VESC setting - all I changed was cutoff start and end, did I miss something???
Go higher with your motor max if the motors can handle it. 60 or 80 for example. Then go higher with your battery max if the batteries can handle it. Maybe 40 for example. And then set the maximum input voltage to 57.
For the motor detection you should take the values which will be entered by the apply button. These are a bit lower than the detected values. And just post all Screenshots you have.
Think I did not hit apply before. Would you happen to know wht the avg distance range for a 6s setup would be? I initially decided to upgrade to 9s to increase my range - was only getting 8 miles from 6s - could be because i had the motor settings wrong?
That depends on the ah the battery has.
6S * 3,7V * 5ah = 111Wh. And in average you need about 10 wh per km. So a 6S 5ah battery would be good for roughly 11 km.
I hate to be such a pain in the arse - I really do appreciate all of the help, BTW. If I am using 3 Zippy 5000mAh 3S1P 20C battery - what should my Batt max setting be?
But 100A would be too much for one VESC. If you have a single and want alot of power the try 50A and if you have 2 motors than use 40A on each. If it is too much then lower it.
