5 minutes later before going outside:
I wanna cry.
We need to make a new base with conical seats in order to be fitted in the conical holes of the trampa deck, I mean these holes:
When you adjust the bolts the base deforms and will eventuattly break.
On the other hand, the distance between holes was larger than the trampa deck, so instead of being 41mm it was 42.5mm that might have contributed to the cracking.
One more thing, the Blitzu lamp should be slided from the top not from the bottom, it will fall as soon as the road transfer the vibrations to the base
gosh, cracked, maybe can try another direction for printing the mount. (horizontal and vertical line).
mmaner
July 28, 2017, 2:01am
43
I can adjust the mounting holes, I’ll do it tomorrow and send you the revision.
In the files there is a plug for the bottom, you use 2 sheet metal screws to install the plug which holds the blitzu in place.
mmaner
July 28, 2017, 7:47pm
44
@Eboosted I updated the model on TV to include the mount holes at 42mm centers. Let me know if you need anything else.
https://www.thingiverse.com/thing:2455515
yup, changing orientation should help. using less infill (20-30%) should make the part more flexible as well
@mmaner I really didn’t want to bother you more brother, but I tried to mod it myself without success.
I’d like to do these modifications:
Turn the squared holder 180 degrees in order to fit the light from the top rather than from the bottom
Lower the holder to be placed below the level of the deck, this way it would be less prone to casual kicks and would look better
mmaner
July 29, 2017, 12:36am
47
Ok, it’ll be when I get back from vacation. I’m leaving tomorrow. So a week plus a couple of days.
No rush man! Thanks a lot! And sorry for being a PIA
mmaner
July 29, 2017, 3:16am
49
No worries, glad to help.
