Bluetooth control of VESC Mode switch?
Hi, I’m half way through a single VESC build…
Is it possible to have 2 switchable modes on the VESC through an iOS app, like learner mode with limited top speed and soft brakes, and beast mode with all power available?
I use perimetr.at to change modes. Takes me a few seconds to switch from 40km/h max speed to 18km/h legal speed.
Which parameters would you change? Is it possible to have gentle active braking to limit the top speed for a novice?
Thanks for helping.
Yeah, just adjust the MAX EERPM. You’ll have to calculate the number though.
http://calc.esk8.it/#{“batt-type-lipo”:1,“batt-cells”:8,“motor-kv”:190,“system-efficiency”:100,“motor-pulley-teeth”:15,“wheel-pulley-teeth”:30,“wheel-size”:90}|
Fill in your stats in the above tool, then check ERPM number, which for me is 39368 RPM. Top speed is 47km/h: 47km/h —> 39368 RPM So for example for a 25km/h limit: 25 km/h —> 20940RPM
Cheers.
