In this case, does this mean I have to connect the balance lead wires in parallel first then connect them to the BMS?
** What app/software do you guys use to make those beautiful wiring diagrams? **
Thanks!
Thanks!
You connect the parallel packs’ balance leads in parallel.
I use pages out of a squared notebook because it helps with my straight lines. And i keep a red and black pen at hand. Free version downloadable from the official site
You can use Paint(you should not) or Inkscape(you should, I do) to make nice vector graphics
So I can use something like this on each parallel connection
or
https://www.progressiverc.com/parallel-balance-board-for-jst-xh.html
Then connect them in series to the BMS.
Yes, use a series connector or if you’re comfortable with soldering you can go that route.
I’m thinking of doing the same thing did you ever try this method?
