Edit: (I found two BMS would you recommend one of the for charging only)?
Hey, i have some questions about a selfmade Liion-Pack. I plant to do it like i draw in the Picture. Maybe if u would say it is better i would do an 4p?
Now the Problem is, where can i buy the Batterys?
Good: In the EU / Better: In Germany …and if it would be cheap then also Asia and CO.
I would be very happy if you could share an link
And the second problem is: (Yes i read the Post about BMS )
Which BMS can you recommend to charge the pack?
Would be also very happy about a Link.
And the most probleme here is how to bypass (I read that in a nother post). Maybe someone have a link to a tutorial. or can draw a shema?
I am an electrician technician, but i dont know how i can charge with the BMS. Do i only put DC-12V to it and the BMS do the rest? or do i need more V then the Pack has (22,2V)
Maybe important Infos: Planned for the board is a SK3~200kv, X-Car ESC
Thanks for all the Help!
