I’m currently using the 50A BMS that came with my original Enertion space cell but it’s likely going to be too big for my new Vanguard deck so I’m looking to replace it with a small BMS just for charging my 10S4P 18650 pack and letting my VESCs and a fuse handle voltage/current regulation. I’m also after an anti spark switch so that I can charge my board with my laptop style charger and not have to worry about removing an XT90S connector to turn my board off.
I’ve had a look at various websites for small BMS’s but would appreciate if someone would be able to make a recommendation for one that they’ve found to be reliable
I’ve seen that @torqueboards and @chaka have options available as far as switches go but I’m wondering if there’s differences between their functionality that I may not know about? @chaka’s Vedder switch looks to include an integrated battery fuse which is handy as it makes for one less extra component I need to think about fitting somewhere else. Other than that, are there any other differences between the two that’re worth noting?
Cheers
