Hello, I’ve bought this BMS sometime ago:
and put a normal switch in series with the temp switch inorder to use it as an E- switch, it used to work untill now but all of a sudden it doesn’t and the BMS is always on no matter the state of the switch or even if the input is open.
How do I fix it? maybe you can reset the BMS you make it work again?
Thanks for helping.
