Have an option of both the 45a is 15$ and the 60A is 45, don’t know if i will pull 60amps from a 10s4p setup with single 190kv motor 1:2 ratio, waiting for the bms for 20 days just to realize that i didn’t even order it and now can rethink the decision, what do you guys think need your help thanks
Anyone used any of these?
Also Im over my budget already so…
Supower and BestTech are known to be somewhat reliable BMS-es. I wouldnt cheap out on them since they can ruin your batteries which are an expensive investment and set your house on fire, maybe im exaggerating but electronics break, but that is a choice to be made by you. Since you are using a low gearing ratio, i would use the 60A one, of course if your cells can take it. It is a pain to butcher a battery after you made it just because your bms cutts of when you ride. @Okami Found out he uses about 1600w on his single drive mountain board, so that may be enough for you. Depends on your expectations from the board.
Newbie here need help choosing a BMS for Dual motor setup
Motors: 6374 190KV
Max Power: 3150 Watts
Max Amps: 80Amps
ESC: EZRun MAX6 V3
Continuous Current: 160A
Peak Current: 1,050A
Running 8s lipo now But going to switch to 18650 battery wired for 8s4P what BMS would you guys recommend?
