Hi there everyone,
I have a question regarding Amp limit caused by the BMS.
I’m at the stage of ordering parts for my first board.
I already ordered and received the motor - Turnigy SK3 6374 192kv which is rated as max 80Amp.
Battery will be a 10s4p LG hg2 (20 Amps continuous each).
The BMS will most likely be:
https://m.banggood.com/37V-42V-10S-45A-Li-ion-Battery-Protection-Board-BMS-PCB-System-p-1177351.html?rmmds=search
Which is rated as 45 Amps continuous (ignore for the fact that it is supposed to withstand 100A instantaneous discharge).
Now:
-The motor max 80 Amps
-The battery is 4p so is capable of 80 Amps
-The BMS is 45 Amps
Does this mean that the BMS will limit the whole system and I will only be able to run 45 Amps?
You’ll want to restrict current on the Vesc. BMS over discharge current will likely just cut out leaving you powerless. Vesc max current will simply reduce your top acceleration and top speed if I’m not mistaken.
If I understand you correctly, you mean that in the current setup the BMS will cut at 45A, and if I want to prevent this from happening I need to disable over-discharge protection?
If so how do I do that? Do I need to modify the BMS in some way?
We’re only talking about 5A, no big deal then No problem if you set 45A as Battmax in your VESC config (which would be limited to 50A anyway). You wouldn’t maybe not see the difference brought by those 5A.
You need to get the specs of the bms to be sure what its parameters are.
If it’s max continuous current is 45a and it’s max peak current is 100a then it’s over current detection should be set around 100a.
Meaning that drawing more than 45a continuously will not shut the bms down but drawing more than 45a continuously could cause it to overheat and that could cause it to shut down if it has over temp protection.
If it doesn’t have over temp protection then overheating it could cause permanent failure.
If your building a single drive street board with vesc, the 45a bms will probably be ok.
Thanks to everyone for your help!
Just to be sure that I understand correctly. Lets say the whole system is rated at 80A except for the BMS whyich is 45A. Does this mean its effecively a 45A system? And the max amps the motor will see is 45A?
@Namasaki
