Yep, got a Metr module.
So sounds like it safe to assume the battery can supply around 40amps and 80peak.
Same i read else where
Yeah I would says that’s a pretty safe assumption. I wouldn’t go much more than 20-25a per Vesc
Yep, only using single drive myself so way under the maximum but better safe then sorry.
20amps is what i plan on using the board at for the rest of its life and just using the battery pack i made now to get it up and running so when ever i get the money for a real pack i no longer would have to worry about vesc settings and i can just enjoy it or if im super lucky and get a good offer on the complete without battery the buyer wont have to do anything else either
Yes. The Evolve BGT, CGT and GTX will pull a max of around 80A peak for a few seconds… It can’t sustain it for any longer. It pulls around 40A continuous though. Even then it will overheat and restrict current if you do that for too long…
Cheap Chinese parts unfortunately. Not even good Chinese parts!
Sooo it works now flawless and hooolyyy fuuuc my board has a lot of power now.
